configure bgp peer-group next-hop-self
configure bgp peer-group peer-group-name {address-family [ipv4-unicast | ipv4-multicast |ipv6-unicast | ipv6-multicast |vpnv4]} [next-hop-self | no-next-hop-self]
Description
Configures the next hop address used in the updates to be the address of the BGP connection originating the update.
Syntax Description
peer-group-name Specifies a peer group.
ipv4-unicast Specifies the IPv4 unicast address family.
ipv4-multicast Specifies an IPv4 multicast address family.
ipv6-unicast Specifies the IPv6 unicast address family.
ipv6-multicast Specifies an IPv6 multicast address family.
vpnv4 Specifies the VPNv4 address family for Layer 3 VPN support.
next-hop-self Specifies that the next hop address used in the updates be the address of the BGP connection originating it.
no-next-hop-self Specifies that the next hop address used in the updates not be the address of the BGP connection originating it (Let the BGP protocol decide the next hop).
Default
If no address family is specified, IPv4 unicast is the default.
Usage Guidelines
This command applies to the current VR or VRF context.
These settings apply to the peer group and all neighbors of the peer group.
If you do not specify an address family, this command applies to the IPv4 unicast address family. To apply this command to an address family other than the IPv4 unicast address family, you must specify the address family.
If the specified peer group contains IPv6 peers, it is an IPv6 peer group and you must specify an IPv6 address-family. When the specified peer group is an IPv6 peer group, this command fails if no address family is specified or if an IPv4 address-family is specified. This command also fails if an IPv6 address family is specified for an IPv4 peer-group.
To configure this feature on Layer 3 VPNs, you must configure this feature in the context of the MPLS-enabled VR; this feature is not supported for BGP neighbors on the CE (VRF) side of the PE router.
The following command configures the next hop address used in the updates to be the address of the BGP connection originating it:
configure bgp peer-group outer next-hop-self
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
